My car wont "Lock" in park?
Airick10
I have a 2005 cobalt, automatic. I can take it out of park, without the key in the ignition, and without pushing the button on the shifter. This really isnt a problem for me, but i just dont want a kid messing around and bump it into neutral or something. Is there an easy fix to this?
utsadude
Columbus(boring), TX
From what I have read there is some clip in the shifter that if you remove it you can do this.
But I am not certain. I don't have an automatic to go look at to help you either.
So potential idea + bump for you.
Airick10
maybe my "clip" is broke? because I can take it out of park without the button, or key
Maven
you most likely need a shifter......the microswitch that tells the car when its in par it actuated by a rod that goes through the shifter, this rod bends and falls out.
Airick10
Just the shifter that is inside the car? Would that be easy to replace?
Maven
easy to replace? yeah its like 4 10mm nuts, a couple connectors and a piece of trim.
hessjacob33
