intake manifold 2007 2.2L
deanwilliams
...so I took off the throttle body and notice fluid in the intake, not a whole lot but is that a normal find?
It depends on what fluid you found. If it's oil and your valve cover vent is hooked up then yes, that is normal.
If you found something other than oil then there might be a problem.
critty84
