Grinding Noise on startup??
lgf1985
Hi everyone. I am new to this forum and I love my 08 Chevy Cobalt. Over the last couple of months ive noticed a grinding noise coming from my car when I start it up. when i drive it, turn it off and come back after while, the noise will not repeat. It only happens when its been sitting around for a while. I turn it on in the morning for work when noise happens and when i leave for work in evening. A buddy of mine suggested that i get thicker oil because it could be the pistons. I am not car savvy so any info would help alot.
this is a the youtube address for the video i captured:
[http://www.youtube.com/watch?v=kpLry5sAs0I ]
lgf1985
So I would have to purchase a new starter?
Sent from my PC36100 using Tapatalk
Jmesl8er
NKY
Thats what it sounds like to me, do you live in a humid area? Wait for some other guys to chime in, but I'm 90% sure
lgf1985
Yea I live in south Texas. Super humid. Would there be any additional damage if I don't change the starter soon. Thanks.
Jmesl8er
NKY
if it is the starter, it'll burn up from not disengaging
Sounds like mine on startup kinda, pretty sure mine is either the HPFP or the VVT.
Where is that sound coming from, top bottom of the motor?
Also, do not get thicker oil. Stick with the stock 5w30.
lgf1985
I don't know what hpfp or vvt is but the noise sounds like its coming from the front driver's side.
chevyd
OMG! My car has been doing the same thing for the past 4 months. No one at the dealership hears it but me. Initially, it was only after it sat but it progressively got worse and is doing it all the time. It's so embarrassing because I would love to get it fixed but no mechanic knows what's going on. Did you ever get it fixed? If so, what was it?
#PIP4716C: Sharp Engine Rattle Noise At Start Up May Also Set P0011 P0014 P0016 P0017 - (Aug 2, 2011)
Subject:
Sharp Engine Rattle Noise At Start Up may also set P0011 P0014 P0016 P0017
Models:
2010 Buick LaCrosse
2009-2010 Chevrolet Cobalt
2010 Chevrolet Equinox
2009-2010 Chevrolet HHR
2009-2010 Chevrolet Malibu
2010-2010 GMC Terrain
2009-2010 Pontiac G5
2009-2010 Pontiac G6
2009-2010 Pontiac Solstice
2009-2010 Saturn Aura
2009-2010 Saturn Sky
2009-2010 Saturn Vue
Equipped with the following engines
2009-2010 2.0L (RPO LNF)
2009-2010 2.2L (RPO LAP/LE8)
2009-2010 2.4L (RPO LE5/LE9/LAT/LAF
This PI was superseded to remove 2011 model years. Please discard PIP4716B.
Condition/Concern:
In rare instances a technician may comment they hear a short, sharp rattle noise from the front of the engine at start up. P0011 P0014 P0016 or P0017 may also set during this condition.
Recommendation/Instructions:
If the noise is from the front accessory drive area, inspect the engine belt. We have seen concerns with engine belts causing a loud ticking type noise. If found, verify power steering pulley outer edge is aligned flush with shaft and repair as needed. If pulley alignment is correct replace the engine belt.
If the noise is still present and is very short and sharp in duration (2-5 seconds). This may be an issue with the cam phasers not parking properly. Once the noise is verified as the phasers, they must be replaced. If the cam phasers are replaced, remove the CMP actuator solenoids to inspect for debris. If debris is found, clean and inspect for torn or loose screens and replace solenoid if necessary.
Note: If debris is found in the solenoids and phasers, change the oil and filter before returning to service, In some instances it may be necessary to change the oil/filter multiple times with a test drive in between each one. The filter and solenoids can be inspected afterwards to ensure no additional debris is present.
critty84
