Dead Battery
[email protected]
OK, I need some help, my car was stolen and I was able to retrieve it. I have a 06 Colbalt LS. The problem is the battery is dead and it's located in the trunk!! The only key I have is stuck in the ignition and I can't get that out unless I can charge the battery. Is there any way to pop the trunk?
Brit
ahh wish i could help. no clue.. but i did have my keys stuck in the ingnition before and took it to the dealer and they got it right out.. something about on the stering column.. had a recall on it, go figure.
CFCobalt
the matrix
really??
there is a pull-out portion (similar to an ash tray) located on the left side of the steering column....the trunk button is in there...
Jmesl8er
NKY
really? didnt know that one....my bad OP:sorrysign:
could you not jumpstart the car? or at least get it enough juice to use the button?
yep^^^^ , theres a place under the hood for jumper cables, put them on there. should be enough juice for the trunk button. if not, get a drill???
hessjacob33
