geffy
Hi. Noob here. '09 Cobalt LS, 2.2 engine. That much I know. I seek further enlightenment.
While trying to change the air filter and get the top undone, I hear a "snap" and find that I've busted a hard plastic hose connected to the air filter housing at one end. The other end is connected to a rubber hose routed somewhere down inside the engine compartment. Car runs with said busted hose (which I have crudely patched), but Check Engine light is now on.
I probably should have tried to remove the hose and the MAF sensor connector first.
Anyway - what is a good name for the hose in question so I can maybe replace it?
Most grateful,
Geff
P.S. Also noticed that a wire is broken on the connector going to the MAF sensor, so for all I know that may be the check engine light issue.
Most grateful,
Geff
